TRENDnet TL2-G244 24-Port Gigabit Layer 2 Switch
Quicklinx: 9QSWWS00 Mfr#: TL2-G244
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
Hurry, only 2 left in stock!
£186.01 ex VAT
£223.21 inc VAT
The 24-port Gigabit Layer 2 switch TL2-G244 provides a reliable foundation for a highly scalable managed network. The TL2-G244 features a 48Gbps switch fabric, 802.1x authentication, SNMP v3, and Multiple Spanning Tree (MSTP) support.
Gigabit Ethernet ports and Mini-GBIC slots provide high speed uplinks to backbone switching or servers. Configure the switch using your choice of Telnet, HyperTerminal, SNMP, or a browser. View statistics captured for 17 unique switching parameters. Additional management features such as port trunking, IGMP snooping, static and dynamic VLAN, load balancing, RMON, QoS, and RSTP allow administrators to effectively manage departmental work groups.
TRENDnet TL2 G244 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x shared Gigabit SFP
MAC Address Table Size
8K entries
Jumbo Frame Support
10000 bytes
Remote Management Protocol
SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Flow control, auto-negotiation, trunking, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, SSH support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 21 cm x 4.4 cm
2.9 kg
3-year warranty
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8K entries
Jumbo Frame Support
10000 bytes
Authentication Method
RADIUS
Built-in Devices
Led panel
Status Indicators
Port status, power, link/activity
24 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC) , 1 x RS-232
Internal power supply
21.79 Watt
1 x serial cable - 3 m
Rack Mounting Kit
Included
FCC, RoHS
44 cm
21 cm
4.4 cm
2.9 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Ports: 24
Managed: Yes
POE: No
Brand: TRENDnet
Price Range Ex VAT: 150 - 300
