The 4-Port USB KVM Switch lets you manage four PC's with just one set of keyboard, monitor, and mouse. Switch between 4 PC's with a simple press of a button! Separate sets of KVM cables are included with the KVM Switch, so users can start controlling 4 PC's instantly. The KVM cables also provide power to the KVM Switch, eliminating the need for a power adapter. Hot Key operations provide immediate access to features such as computer switching, and auto-scanning. With its Hot-Plug, and Audible Feedback, the 4-Port USB KVM Switch is the perfect choice for managing multiple PC's.
Manage up to 4 computers/servers with one set of console devices
USB keyboard/mouse emulation with 4 sets of detachable KVM cables
Compliant with Windows, Linux, and Mac OS
High video quality, up to 2048 x 1536 VGA resolution
Auto-Scan and LED display for computer monitoring
Keyboard status restored when switching between computers
Computer selection by front panel push buttons, keyboard hot key commands or Windows-based client switching software*
User definable hot key (Windows only)
Plug & Play and hot-pluggable
USB interface power method
2-year limited warranty
- TRENDnet TK 407K - KVM switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- 16.7 cm x 8 cm x 2.8 cm
- 159 g
- System Requirements
- Microsoft Windows 98, Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536
- 4 x KVM HD-15 , 2 x USB Type A , 1 x VGA HD-15
- Cables Included
- 4 x keyboard / mouse / video cable
- Plug and Play, FCC, RoHS
- OS Required
- 16.7 cm
- 8 cm
- 2.8 cm
- 159 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90%
TRENDnet TK-407K 4-Port USB KVM Switch Kit
