TRENDnet's 2-port HDMI KVM switch, model TK-215i, controls two computers with one set of console controls. No driver installation required, simply plug in the integrated cables to share two computers with a Full HD 1080p display. The TK-215i supports HDMI and 3.5 mm analog audio and features an ergonomic computer toggle switch.
1080p HD
Supports Full HD 1080p with a 60 Hz refresh rate. -
2-way audio
Full audio support through HDMI cable connections with 3.5 mm microphone and speaker jacks. -
Toggle switch
Use the integrated 1.5 m cable to position the toggle switch in the most ergonomic location. -
Console connectors
Emulation technology supports advanced USB keyboard and mouse designs.
- TRENDnet TK 215i - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- USB powered, 5.1 channel audio support, toggle switch
- 8.5 cm x 5.8 cm x 2.8 cm
- 350 g
- 2 years warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1080 @ 60 Hz
- Built-in Devices
- Led panel
- Status Indicators
- Status
- 2 x HDMI , 2 x USB 2.0 , 2 x audio mini-jack , 2 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 1 x microphone mini-jack , 1 x audio mini-jack , 1 x HDMI
- Cables Included
- 2 x keyboard / mouse / video / audio cable - 85 cm
- Plug and Play, FCC, RoHS, WEEE
- 8.5 cm
- 5.8 cm
- 2.8 cm
- 350 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
