Product
TRENDnet TK-209K 2-Port USB KVM Switch Kit with Audio
Quicklinx: 9758WS00 Mfr#: TK-209K
The 2-Port USB Audio KVM Switch lets you control multimedia PCs with just one keyboard, monitor, mouse, microphone, and a set of speakers. The KVM switch not only allows you to share your monitor, keyboard and mouse but you can also share microphone and speakers. With just a simple press of a button, this KVM switch eliminates the hassle of cable swapping and switching between 2 PCs. With it's Hot-Plug, Auto-Scan and Hot-Key operating features, the TK-209K is the perfect choice for managing 2 PCs. Separate KVM cables are included.
Control up to 2 computers/servers with one set of console device
USB keyboard/mouse emulation with 2 sets of detachable KVM cables
Compliant with Windows, Linux and Mac OS.
High video quality, up to 2048 x 1536 VGA resolution
Listen to music from one computer while working on the other
Auto-Scan & LED display for computer monitoring
Computer selection by face panel push buttons, keyboard hot key commands or Windows-based client switching software*
User definable hot key (Windows only)
Plug & Play and hot-pluggable
USB interface power method
2-year limited warranty
TRENDnet TK 209K - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
On-Screen Display, USB powered
USB 1.1
9.8 cm x 7 cm x 2.8 cm
100 g
Microsoft Windows 98, Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
USB 1.1
2 x VGA HD-15 , Audio: 2 x 4 pin mini-USB Type B , 1 x VGA HD-15 , 2 x USB Type A , 1 x microphone input mini-jack , 1 x audio output mini-jack
2 x VGA / audio cable - 1.2 m , 2 x audio cable
Plug and Play, FCC
Software Included
Drivers & Utilities
9.8 cm
7 cm
2.8 cm
100 g
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
