Your basket is empty
TRENDnet THA-103AC Home Smart Switch with AC Wifi Extend
Quicklinx: BKGPWS00 Mfr#: THA-103AC
  • IEEE 802.11n
£23.01 ex VAT
£27.61 inc VAT
TRENDnet's Home Smart Switch with Wi-Fi AC Extender, model THA-103AC, is a combination smart electrical outlet and powerful AC750 wireless extender. Use the free Apple or Android mobile app from any internet connection to turn on and off a light, fan, electronic device, or appliance. Create a daily schedule to turn on/off the outlet to match your needs or to give the illusion that you're home. Place the THA-103AC in an area of your home with low wireless coverage - the powerful built-in Wi-Fi extender connects to either an existing Wi-Fi AC or Wi-Fi N router and broadcasts two concurrent Wi-Fi AC433 and N300 networks.
TRENDnet THA-103AC Home Smart Switch - Wi-Fi range extender
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
5.9 cm x 3.7 cm x 9.4 cm
194 g
3 years warranty
5.9 cm
3.7 cm
9.4 cm
194 g
External
Wireless
Data Transfer Rate
433 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz, 5 GHz
Remote Power On, remote Power Off, Wi-Fi Protected Setup (WPS), integrated power socket, reset button, over-current protection
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Aerial
Antenna
External detachable
Antenna Qty
2
FCC
Internal power supply
6 Watt
Limited warranty - 3 years
0 - 95% (non-condensing)
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
