TRENDnet’s AC1750 Dual Band Wireless Router with StreamBoost™ Technology, model TEW-824DRU, is built to perform in a busy connected home. It generates two concurrent WiFi networks—a 1,300 Mbps WiFi AC and a 450 Mbps WiFi N network. Qualcomm® StreamBoost™ technology prioritizes low latency gaming and voice streams, shapes network traffic to optimize each connected experience, and graphically displays all connected device/application traffic. Use the Gigabit Ethernet ports and USB share port to further extend an extreme performance digital network.
Optimized Gaming
StreamBoost™ minimizes latency for gaming, video, and voice streams to eliminate stutter and lag caused by high bandwidth traffic such as torrents.
Built For Busy Homes
Concurrent extreme WiFi networks and all Gigabit ports seamlessly network connected devices and high bandwidth streams such as 4K video.
Network Protection Tools
TRENDnet includes tools to help protect your home network including parental controls, isolated guest networks, and pre-encrypted WiFi.
Optimized Gaming
When latency is the difference between winning and losing, Streamboost has your back. It helps eliminate hated stutter and lag with a laser focus on providing the lowest latency possible. When high bandwidth traffic is killing other networks, Streamboost thrives by prioritizing gaming, video, and voice over other non-critical data streams.
Traffic Shaping
StreamBoost dynamically shapes network traffic, delivering an optimized user experience, as applications and devices become active. Out of the Box, Streamboost automatically identifies, classifies, and intelligently manages all traffic. No user management is required. However, users can choose to manually override default device priority.
App + Device Aware
With more devices and applications downloading, streaming, and playing than ever before, today's home network needs a smarter way to deliver the best online experience. StreamBoost does just that. Constant updates provide the ability to identify new-to-market applications and devices and maintain an optimized experience as your home network changes.
Traffic Mapping
See your smart phones, tablets, computers, game consoles, and all other connected devices graphically mapped with their respective upload and download bandwidth usage. Select a device such as your computer to see detailed network loading of all of its applications and programs. This powerful network map feature is a great troubleshooting tool.
Easy Setup
Get up and running in minutes with the intuitive guided setup
Simultaneous AC1750 Dual Band
Concurrent high performance 1,300 Mbps WiFi AC + 450 Mbps WiFi N bands
Qualcomm® StreamBoost™ Latency Prioritization
StreamBoost™ prioritizes latency for gaming and voice streams to eliminate stutter or lag caused by other high bandwidth network traffic such as torrent downloads
Qualcomm® StreamBoost™ Traffic Shaping
StreamBoost™ intelligently allocates the optimal amount of bandwidth for each individual device/application and users can further manually assign device priority
Device/Traffic Mapping
See all connected network devices/applications and their respective real-time network usage and review historical usage data
Pre-Encrypted Wireless
For your convenience the WiFi is pre-encrypted with its own unique password
Wireless Coverage
High performance amplifiers maximize wireless coverage
Gigabit Ports
Gigabit ports support high performance wired connections
USB Share Port
Share content across the network with the USB share port
Guest Network
Create an isolated network for guest internet access only
Parental Controls
Control access to specific websites or types of content
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Targeted Beamforming
Increased real-time performance by directing stronger wireless signals to your specific location
Backward Compatible
Compatible with legacy wireless devices
Energy Savings
Embedded GREENnet technology reduces power consumption
- TRENDnet TEW-824DRU - wireless router - 802.11a/b/g/n/ac - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.3 Gbps
- PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, CSMA/CA, DDNS, DHCPv6
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- TFTP
- VoIP Protocols
- H.323, SIP
- NAT support, Stateful Packet Inspection (SPI), ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, virtual server support, iTunes server, Wi-Fi Protected Setup (WPS), Samba support, FTP server, BitTorrent Client, reset button, StreamBoost
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 15.1 cm x 7.2 cm x 19.1 cm
- 408 g
- 3 years warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.3 Gbps
- Routing Protocol
- TFTP
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, FCC
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
IP Telephony
- VoIP Protocols
- H.323, SIP
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Voltage Required
- 18 Watt
- Cables Included
- 1 x network cable - 1.5 m
- 15.1 cm
- 7.2 cm
- 19.1 cm
- 408 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
