TRENDnet TEW-816DRM AC750 Dual Band Wireless VDSL2/ADSL2+ Router
Quicklinx: B88CWS00 Mfr#: TEW-816DRM
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 433Mbps
Rackmount or External: External
  • IEEE 802.11n
More than 50 in stock
£55.41 ex VAT
£66.49 inc VAT
TRENDnet's wireless modem router TEW-816DRM offers a combination of high performance modem for Internet access and powerful wireless router. The built-in modem supports ADSL2+ and VDSL2 standards for high downstream speeds. Use USB and Ethernet ports to share content and devices across the network.
  • High speed Internet
    The built-in extreme performance modem supports high Internet speeds.
  • Wi-Fi for all
    Connect all your Wi-Fi devices to Wi-Fi networks.
  • USB share ports
    Plug in USB flash or storage drives to USB ports to share content across your network.
TRENDnet TEW-816DRM - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Network / Transport Protocol
PPTP, L2TP, ICMP/IP, IPSec, PPPoE, PPPoA, IPoA, FTP, DHCP, DDNS
Routing Protocol
RIP-1, RIP-2, IGMP, static IP routing, MLD
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, TFTP, SSH, TR-069
NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, ALG support, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, firmware upgradable, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), Samba support, reset button, on/off switches
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
19 cm x 14.6 cm x 5.5 cm
323 g
3-year warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Routing Protocol
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.1 (G.DMT) Annex B, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.5 Annex A, ITU G.992.5 Annex L, ITU G.992.5 Annex B, ITU G.992.5 Annex J
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
14 Watt
1 x network cable - 1.5 m , 1 x modem cable - 1 m
19 cm
14.6 cm
5.5 cm
323 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 433Mbps
Brand: TRENDnet
Price Range Ex VAT: 50 - 100
