TRENDnet's AC600 high gain dual band wireless USB adapter, model TEW-806UBH, connects a Windows or Mac computer to a revolutionary wireless AC network. Connect to a wireless AC network at 433 Mbps or to a wireless N network at up to 150 Mbps. This adapter features an adjustable high gain antenna which significantly increases wireless coverage.
Easy Setup
Get up and running in minutes with the intuitive guided setup
Operating Systems
Compatible with Windows® and Mac® operating systems
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Performance
High Gain Antenna - An adjustable high gain antenna significantly increases wireless coverage
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Dual Band
High speed 433 Mbps Wireless AC + 150 Mbps Wireless N bands
Encrypted Wireless
Supports the latest encryptions standards (up to WPA2)
Backward Compatible
Compatible with legacy wireless devices
For maximum performance connect to an 802.11ac wireless router or access point
*Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions.
Easy setup
Get up and running in minutes with the intuitive guided setup. -
One touch connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button. -
High gain antenna
An adjustable high gain antenna significantly increases wireless coverage. -
Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home.
- TRENDnet TEW-806UBH - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 18.8 cm x 1.7 cm x 1.8 cm
- 17 g
- Data Link Protocol
- 802.11a, 802.11b/g/n, Wi-Fi 5
- Data Transfer Rate
- 433 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, USB 1.1, USB 2.0, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.6 - 10.9, Microsoft Windows Vista / 7 / 8 / 8.1
- 3-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- 433 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- WPS
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Gain Level
- 5 dBi
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- FCC, RoHS
- OS Required
- 18.8 cm
- 1.7 cm
- 1.8 cm
- 17 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
