Product
Brand
TRENDnet TEW-806UBH AC600 High Gain Dual Band Wireless USB Adapter
Quicklinx: 9Y0RWS00 Mfr#: TEW-806UBH
  • IEEE 802.11n
TRENDnet's AC600 high gain dual band wireless USB adapter, model TEW-806UBH, connects a Windows or Mac computer to a revolutionary wireless AC network. Connect to a wireless AC network at 433 Mbps or to a wireless N network at up to 150 Mbps. This adapter features an adjustable high gain antenna which significantly increases wireless coverage.
Easy Setup
Get up and running in minutes with the intuitive guided setup
Operating Systems
Compatible with Windows® and Mac® operating systems
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Performance
High Gain Antenna - An adjustable high gain antenna significantly increases wireless coverage
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Dual Band
High speed 433 Mbps Wireless AC + 150 Mbps Wireless N bands
Encrypted Wireless
Supports the latest encryptions standards (up to WPA2)
Backward Compatible
Compatible with legacy wireless devices
For maximum performance connect to an 802.11ac wireless router or access point
Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions.
TRENDnet TEW-806UBH - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
18.8 cm x 1.7 cm x 1.8 cm
17 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac (draft 2.0)
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, USB 1.1, USB 2.0, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Microsoft Windows XP, Apple MacOS X 10.6 - 10.9, Microsoft Windows Vista / 7 / 8 / 8.1
3 years warranty
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link/activity
Aerial
Antenna
External detachable
Antenna Qty
1
Gain Level
5 dBi
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
18.8 cm
1.7 cm
1.8 cm
17 g
Limited warranty - 3 years
0 - 90% (non-condensing)
