TRENDnet TEW-805UB AC1200 Dual Band Wireless USB Adapter
Quicklinx: 8QW6WS00 Mfr#: TEW-805UB
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac (draft 2.0), IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
  • Windows 8 (32/64 bits)
£19.23 ex VAT
£23.07 inc VAT
TRENDnet's AC1200 Dual Band Wireless USB Adapter, model TEW-805UB, connects a laptop or desktop computer to a revolutionary Wireless AC network. Connect to a Wireless AC network at an amazing 867 Mbps or to a Wireless N network at up to 300 Mbps. A SuperSpeed 5 Gbps USB 3.0 port maintains a high speed connection to your computer.
Quickly connect to a Wireless AC or N network at the touch of a button with the convenience of one-touch Wi-Fi Protected Setup (WPS). An LED on the front of the adapter conveys device status. Upgrade your computer's wireless connection to experience the speed of revolutionary Wireless AC.
Wireless AC: Next generation Wireless AC
Dual Band: Up to 867 Mbps Wireless AC or 300 Mbps Wireless N
Compatible: Connects to standard Wireless N networks
USB 3.0: SuperSpeed 5 Gbps USB 3.0 connection to computer
Coverage: Expanded coverage with MIMO technology
One Touch Connection: Connect to a router at the touch of the Wi-Fi Protected Setup (WPS) button
TRENDnet TEW-805UB - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
8 cm x 2.7 cm x 1.2 cm
20 g
802.11a, 802.11b/g/n, 802.11ac (draft 2.0)
Data Transfer Rate
867 Mbps
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 1.1, USB 2.0, IEEE 802.11n, USB 3.0, IEEE 802.11ac (draft 2.0)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
3-year warranty
Network adapter
External
SuperSpeed USB 3.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Data Transfer Rate
867 Mbps
CSMA/CA
Line Coding Format
128 QAM, DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Max Range Indoors
100 m
Max Range Open Space
300 m
Status Indicators
Status
MIMO technology, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB - 4 pin USB Type A
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA2-PSK
ETSI, FCC
Software Included
Drivers & Utilities
8 cm
2.7 cm
1.2 cm
20 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Protocol: IEEE 802.11ac (draft 2.0)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
