TRENDnet's N600 Dual Band PoE Access Point, model TEW-753DAP, is a feature rich business class access point with proven concurrent 300 Mbps dual band wireless technology. A variety of installation scenarios are supported with Access Point, WDS AP, WDS Bridge, and Repeater modes. Save installation time and costs with PoE.
Low profile
Off white low profile smoke detector shape blends into most environments. -
Power over Ethernet (PoE)
Save installation time and costs with a PoE (Optional power port for non-PoE installations). -
Concurrent dual band
Proven concurrent 300 Mbps dual band wireless N. -
Gigabit port
Gigabit port maintains high performance connection to network. -
Wireless coverage
Increased coverage with MIMO technology. -
Backward compatible
Compatible older wireless G devices. -
Operation modes
Independently set each band to Access Point, WDS AP, WDS bridge, or repeater mode. -
IPv6
IPv6 support. -
AP scan
Integrated wireless scan function helps optimize wireless setup. -
SSIDs
Up to 8 SSIDs per band (16 total) with isolation support. -
Traffic shaping
Allocate bandwidth to each wireless SSID. -
System logs
Eight system logs aid network troubleshooting. -
SNMP
Extend network monitoring to this device with SNMP support. -
Encrypted wireless
Support for encryption up to WPA2.
- TRENDnet TEW 753DAP - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 16
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 16.5 cm x 16.5 cm x 4 cm
- 285 g
- 3-year warranty
- 16.5 cm
- 16.5 cm
- 4 cm
- 285 g
- Enclosure Colour
- Off-white
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Repeating mode, traffic shaping, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, MIMO technology, wireless bridge mode, tagged VLAN, SNMP support
- Encryption Algorithm
- WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.3x, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3az
- 1 x 1000Base-T (PoE) - RJ-45
- Cables Included
- 1 x network cable - 1.5 m
- FCC
- PoE
- Power Device
- External power adapter
- Voltage Required
- 12 Watt
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 90% (non-condensing)
