TRENDnet's N600 Dual Band Wireless Router, model TEW-752DRU, offers proven concurrent Dual Band 300 Mbps wireless n networking, Gigabit wired Ethernet ports, and a convenient USB share port. Embedded GREENnet technology reduces power consumption by up to 50%. For your security this router comes pre-encrypted and features guest networks.
- TRENDnet TEW-752DRU - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- Routing Protocol
- Static IP routing
- Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), dynamic DNS server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, GREENnet technology, MIMO technology, Quality of Service (QoS), virtual server support, Wireless Guest Services, DHCP server, port forwarding, reset button, pre-encrypted, Internet Bandwidth Control
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP
- Power
- AC 120/230 V (50 - 60 Hz)
- 4.5 cm x 11.8 cm x 16.4 cm
- 255 g
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS, WEEE
- Status Indicators
- Power, WAN, wireless, USB, WPS
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- WAN: 1 x 1000Base-T - RJ-45 , LAN: 1 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- 14.7 Watt
- Cables Included
- 1 x network cable - 1.5 m
- 4.5 cm
- 11.8 cm
- 16.4 cm
- 255 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
