TRENDnet's plenum rated business class N300 High Power PoE Access Point, model TEW-735AP, greatly increases wireless coverage as compared to standard access points. A variety of installation scenarios are supported with Access Point, WDS AP, WDS Bridge, and Repeater modes. Save installation time and costs with PoE.
- TRENDnet TEW 735AP N300 High Power PoE Access Point - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Capacity
- Maximum number of configured SSIDs: 4
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 12.8 cm x 12.8 cm x 6 cm
- 210 g
- 3-year warranty
- 12.8 cm
- 12.8 cm
- 6 cm
- 210 g
- Enclosure Colour
- Off-white
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP 1, SNMP 2c
- Frequency Band
- 2.4 GHz
- Capacity
- Repeating mode, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, plenum-rated, tagged VLAN
- Encryption Algorithm
- WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 4 dBi
- 1 x 100Base-TX (PoE) - RJ-45
- FCC
- PoE
- Power Device
- External power adapter
- Voltage Required
- 6 Watt
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 90% (non-condensing)
