Your basket is empty
TRENDnet TEW-735AP N300 High Power PoE Access Point
Quicklinx: 9CTMWS00 Mfr#: TEW-735AP
  • IEEE 802.11n
TRENDnet's plenum rated business class N300 High Power PoE Access Point, model TEW-735AP, greatly increases wireless coverage as compared to standard access points. A variety of installation scenarios are supported with Access Point, WDS AP, WDS Bridge, and Repeater modes. Save installation time and costs with PoE.
TRENDnet TEW 735AP N300 High Power PoE Access Point - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Maximum number of configured SSIDs: 4
Power Over Ethernet (PoE) Supported
PoE
12.8 cm x 12.8 cm x 6 cm
210 g
3 years warranty
Radio access point
12.8 cm
12.8 cm
6 cm
210 g
Enclosure Colour
Off-white
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, SNMP 2c
Frequency Band
2.4 GHz
Repeating mode, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, plenum-rated, tagged VLAN
Encryption Algorithm
WPA2
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
4 dBi
1 x 100Base-TX (PoE) - RJ-45
FCC
PoE
External power adapter
6 Watt
Limited warranty - 3 years
45 °C
0 - 90% (non-condensing)
