RENDnet's N600 Wireless Dual Band PCIe Adapter, model TEW-726EC, upgrades a desktop computer to proven 300 Mbps dual band wireless speed and coverage.
- TRENDnet TEW-726EC - network adapter - PCIe
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- 6.6 cm 5.5 cm
- 45 g
- Data Link Protocol
- 802.11a, 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 3-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- DSSS
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz, 5 GHz
- Max Range Indoors
- 100 m
- Max Range Open Space
- 300 m
- Status Indicators
- Status, transmit, WPS
- MIMO technology, WMM support, QoS, WPS, DSSS
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- Compatible Slots
- 1 x PCI Express x1
- Connections
- 2 x antenna - SMA
- Included Accessories
- Low-profile bracket, full-height bracket
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA2-PSK
- ETSI, FCC, RoHS, WEEE
- Software Included
- Drivers & Utilities
- OS Required
- 6.6 cm
- 5.5 cm
- 45 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
