Product
Brand
TRENDnet TEW-726EC N600 Wireless Dual Band PCIe Adapter
Quicklinx: 9CTDWS00 Mfr#: TEW-726EC
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
RENDnet's N600 Wireless Dual Band PCIe Adapter, model TEW-726EC, upgrades a desktop computer to proven 300 Mbps dual band wireless speed and coverage.
TRENDnet TEW-726EC - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
6.6 cm 5.5 cm
45 g
802.11b, 802.11a, 802.11g, 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
3 years warranty
Network adapter
Plug-in card
PCI Express x1
Wireless
Spread Spectrum Method
DSSS
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Max Range Indoors
100 m
Max Range Open Space
300 m
Status Indicators
Status, transmit, WPS
MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Direct Sequence Spread Spectrum (DSSS)
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
2 dBi
Compatible Slots
1 x PCI Express x1
2 x antenna - SMA
Low-profile bracket, full-height bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA2-PSK
ETSI, FCC, RoHS, WEEE
Software Included
Drivers & Utilities
6.6 cm
5.5 cm
45 g
Limited warranty - 3 years
0 - 90% (non-condensing)
