TRENDnet's N300 Wireless ADSL 2+ Modem Router, model TEW-722BRM, is a combination high performance modem for Internet access and powerful wireless N300 router--well suited for medium to large size homes. The modem is compatible with most ADSL Internet service provider networks and it comes with an intuitive guided setup wizard. For your convenience the wireless network is setup and pre-encrypted out of the box.
Easy Setup
Get up and running in minutes with the intuitive guided setup
Internet Service
Compatible with most ADSL 2/2+ internet service provider networks
N300 Wireless
Powerful 300 Mbps Wireless N
Wireless Coverage
Whole home wireless coverage with MIMO antenna technology for medium to large size homes
Pre-Encrypted Wireless
For your convenience the wireless network arrives pre-encrypted with its own unique password
Guest Network
Create an isolated network for guest internet access only
Wireless On/Off Button
Enable or disable the wireless network with the convenient on/off wireless button
One Touch Connection
Connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Parental Controls
Control access to specific websites and manage which devices can access the router
Advanced QoS
Classify and prioritize different types of data such as video and audio transmissions
Energy Savings
Embedded GREENnet technology reduces power consumption by up to 50%
Ethernet Ports
Four Ethernet ports to hardwire devices
IPv6
IPv6 network support
Easy setup
Get up and running in minutes with the intuitive guided setup. -
Internet service
Compatible with most ADSL 2/2+ Internet service provider networks. -
Wireless coverage
Whole home wireless coverage with MIMO antenna technology for medium to large size homes. -
Pre-encrypted wireless
For your convenience the wireless network arrives pre-encrypted with its own unique password. -
Guest network
Create an isolated network for guest Internet access only. -
Wireless On/Off button
Enable or disable the wireless network with the convenient on/off wireless button. -
One touch connection
Connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button. -
Parental controls
Control access to specific websites and manage which devices can access the router. -
Advanced QoS
Classify and prioritize different types of data such as video and audio transmissions. -
Energy savings
Embedded GREENnet technology reduces power consumption significantly.
- TRENDnet TEW-722BRM - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- Maximum number of configured SSIDs: 4
- PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, CSMA/CA, DHCPv6
- Routing Protocol
- RIP-1, RIP-2, IGMP, static IP routing, MLD
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, HTTPS, CLI, TR-069, TR-098, TR-111
- Flow control, firewall protection, NAT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, domain blocking, GREENnet technology, firmware upgradable, Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), reset button, IPv4 support, Strict Priority (SP), Loopback
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 12.6 cm x 10.9 cm x 2.5 cm
- 158 g
- 3-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Selectable Channels Qty
- 13
- Capacity
- Routing Protocol
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, ETSI, FCC
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- ADSL2, ADSL2+
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.1 (G.DMT) Annex B, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.5 Annex L, ITU G.992.3 Annex J, ITU G.992.3 Annex I
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Gain Level
- 4 dBi
- Power Device
- External power adapter
- Voltage Required
- 4 Watt
- Cables Included
- 1 x network cable - 1.5 m
- 12.6 cm
- 10.9 cm
- 2.5 cm
- 158 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
