The Gigabit PCI Express Adapter is a high performance network adapter that supports advanced management and power savings functionality for system administrators. Full-duplex technology generates data rates of up to 2Gbps over a motherboard's high-speed PCI Express bus architecture. Jumbo Frame support further optimizes throughput performance.
It supports SNMP v1, Remote Program Load (RPL) and Wake-on-LAN (WOL). It also optimizes network performance with VLAN tagging and layer 2 priority tagging and optimizes power consumption with Advanced Configuration Power Management Interface 2.0 (ACPI) technology.
- TRENDnet TEG-ECTX - network adapter
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- PCI Specification Revision
- PCIe 1.0a
- Ports
- Gigabit Ethernet
- 10.9 cm x 8.3 cm
- 80 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
- System Requirements
- Novell NetWare 5.0, Microsoft Windows 2000 Server, Novell NetWare 6, Microsoft Windows XP 64-bit Edition, Linux 2.4, Microsoft Windows Server 2003, Linux 2.6, Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / 2000 / XP
- Environmental Standards
- ENERGY STAR Qualified
- 5 years warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI Express
- PCIe 1.0a
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Remote Management Protocol
- SNMP 1
- Status Indicators
- Link/activity
- Flow control, full duplex capability, RPL support, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI Express
- ACPI 2.0, FCC, RoHS
- ENERGY STAR Certified
- Software Included
- Drivers & Utilities
- OS Required
- 10.9 cm
- 8.3 cm
- 80 g
- Limited warranty - 5 years
- 0 °C
- 45 °C
- 5 - 95%
