TRENDnet TE100-S8 8-Port 10/100Mbps GREENnet Switch
Quicklinx: 975FWS00 Mfr#: TE100-S8
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Managed: No
POE: No
10 in stock
£13.97 ex VAT
£16.76 inc VAT
The compact 8-Port 10/100 Mbps GREENnet Switch, model TE100-S8, offers plug and play switching reliability and reduced power consumption. Embedded GREENnet technology reduced power consumption by up to 40% out of the box, with no management requirement. This switch offers speeds of up to 200 Mbps per port and total switching capacity of 1.6 Gbps.
Easy Setup
Plug and play out of the box
Compact
Compact design fits in a crowded desktop
Traffic Management
Non-blocking wire-speed architecture
Ethernet Ports
Up to 200 Mbps per port and total switching capacity of 1.6 Gbps
Power Savings
Power saving GREENnet technology reduces power consumption by up to 40%
TRENDnet TE100 S8 - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
Switching fabric bandwidth: 1.6 Gbps
MAC Address Table Size
1K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, GREENnet technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
14 cm x 7.5 cm x 2.8 cm
126 g
3-year warranty
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
1K entries
RAM
56 KB
8 x 100Base-TX RJ-45
External power adapter
1.4 Watt
Plug and Play, FCC
14 cm
7.5 cm
2.8 cm
126 g
Limited warranty - 3 years
50 °C
0 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 8
Managed: No
POE: No
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
