Your basket is empty
TRENDnet TC-NT3 VDV & USB Cable Tester
Quicklinx: B3Y0WS00 Mfr#: TC-NT3
Type: Network tool/tester kit
2 in stock
£57.46 ex VAT
£68.95 inc VAT
Standard delivery Delivered within 3-5 working days
TRENDnet's VDV & USB cable tester, model TC-NT3, is a comprehensive cable tester for network professionals. It accurately tests a variety of voice, data, video, and USB cables. The TC-NT3 identifies proper, severed, short circuit, and cross connected pins for cable distances of up to 300 meters.
Quick test mode issues a pass/fail for large test batches.
All components fit into a convenient travel case.
TRENDnet TC-NT3 - network tester
Network tester
Cable Types
CAT3, CAT4, CAT5, CAT5e, coax, CATV, CAT6, CAT6a, CAT6e, CAT7, CAT8, CAT3e
Tests, Tools and Measurements
Tests for crossed wires, short circuit, grounding
Cable tone generator
11.7 cm x 6.7 cm x 2.7 cm
114 g
1 year
Network tester
Media
Copper
Cable Types
Carrying pouch, 2 x RJ-45 to F-connector adapters
1 x RJ-45 to RJ-45 patch cable - 15 m
Connectors
RJ-45, RJ-12, RJ-11, 9 pin USB type A, 9 pin USB type B, RJ-9, RJ-14, RJ-25, RJ-61
Warranty
1 year
Voltage
9 V
Included Qty
0
Required Qty
1
11.7 cm
6.7 cm
2.7 cm
114 g
50 °C
0 - 95% (non-condensing)
Brand: TRENDnet
Price Range Ex VAT: 50 - 100
