TRENDnet Powerline 500 AV Nano Adapter Kit
HOMEPLUG PAIR - PERFECT FOR SMART TV
Quicklinx: 8KC8WS00 Mfr#: TPL-406E2K
Kit - Contains 2 Units
The Powerline 500 AV nano adapter kit, model TPL-406E2K, uses any electrical outlet to create a secure high speed network. Connect the first adapter to your network and plug the second adapter into any outlet on your electrical system for instant high speed network access. The compact form factor saves space around crowded electrical outlets. This adapter automatically connects to other TRENDnet Powerline AV adapters with no installation required - TRENDnet recommends pressing the 'sync' button to automatically change default encryption keys.
Use up to 8 adapters to network devices in different rooms without running new cabling. Power save mode reduces power consumption by up to 80%. Quality of Service (QoS) technology prioritizes video, audio, and online gaming. LED displays convey device status for easy troubleshooting. Advanced 128-bit AES encryption secures your network. This adapter is ideal for use in buildings that interfere with wireless networking signals.
TRENDnet TPL-406E2K - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Maximum of neighbouring networks : 4 , Nodes : 8
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), IPv6 support, full duplex mode, Quality of Service (QoS), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
AC 120/230 V ( 50/60 Hz )
5 cm x 7 cm x 4.3 cm
51 g
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901 , FCC, RoHS
Status Indicators
Link activity, power
Line Properties
Line Coding Format
8 QAM, 64 QAM, 256 QAM, BPSK, QPSK, OFDM , ROBO, 1024 QAM
1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
2.2 Watt
TRENDnet 500Mbs Compact Powerline AV Adapter TPL-406E
2 x network cable - 1.5 m
Software Included
Drivers & Utilities
5 cm
7 cm
4.3 cm
51 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
0 - 95% (non-condensing)
