The Outdoor 3MP Full HD PoE Day/Night Network Camera, model TV-IP311PI, provides powerful 3 megapixel night vision in complete darkness for up to 25 meters (82 ft.). This ultra-compact vandal resistant fixed dome camera is outdoor ready with an IP66 weather rated housing. It comes with a free Apple® and Android™ mobile app and Complimentary pro-grade software to manage up to 32 TRENDnet cameras.
Hardware
PoE - Save installation costs with Power over Ethernet (PoE)
Power Port
Optional power port for non-PoE installation
Outdoor Ready
Outdoor IP66 weather rated
Vandal Resistant
Impact protection rated: IEC60068-275Eh, 50J; EN50102, exceeding IK10
Performance
3 Megapixel
Record 2048 x 1538 pixel video at 15 fps in H.264 compression
Night Vision
Night vision up to 25 meters (82 ft.) in complete darkness
Smart IR
Dynamic IR adjustment optimizes night visibility
Digital Zoom
Digitally zoom anywhere within the viewing field
IPv6
IPv6 support
Advanced Playback
Advanced in-camera archived video review functionality
D-WDR
Digital Wide Dynamic Range improves video quality in high contrast lighting environments
Storage
Samba video support with notification if storage drive is full
Free Apps
See live video on a mobile device with free Apple® and Android™ apps
Complimentary Software
- TRENDnet TV IP311PI Outdoor 3 MP PoE Dome Day/Night Network Camera - network surveillance camera
- Network surveillance camera - pan / tilt - outdoor - tamper-proof / weatherproof
- 11 cm x 11 cm x 8.2 cm
- 456 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 2048 x 1536
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3" - 3 MP
- Minimum Illumination
- 0 lux - IR , 0.05 lux - colour
- Focal Length
- 4 mm
- Focus Adjustment
- (min distance 20 cm)
- Lens Iris
- F/1.2
- Panning Range (degree)
- 356
- Tilting Range (degree)
- 15 to 90
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Backlight Compensation (BLC), digital noise reduction, date/time stamp, sharpness control, white balance, saturation control, brightness control, contrast control, e-mail alerts, image flip, image mirror, ONVIF support, manually schedule recording, Motion Detection Technology, built-in IR illuminator, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), hue control, ONVIF V2.2 (Profile S) support, reset button, Text Caption Overlay, snapshot function
- 3-year warranty
- Environmental Parameters (operating)
- -25 °C - 60 °C; 0 - 90% (non-condensing) relative humidity
- Wired
- 11 cm
- 11 cm
- 8.2 cm
- 456 g
Camera
- Colour - Day&Night - pan / tilt - outdoor - tamper-proof / weatherproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 2048 x 1536
- Motion Detection
- Video Capture
- 2048 x 1536 @ 15 fps , 1920 x 1080 @ 30 fps , 704 x 480 @ 30 fps
- Still Image Capture Resolution
- 704 x 480, 2048 x 1536, 1920 x 1080
Image Sensor
- 3 MP CMOS 1/3"
Lens Construction
- Focal Length
- 4 mm
- Lens Iris
- F/1.2
- Min Focus Distance
- 20 cm
- Horizontal Field of View (degree)
- 70
- Vertical Field of View (degree)
- 52
Panning
- Range (degree)
- 356
Tilting
- Range (degree)
- 15 to 90
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, SSL, Samba, CIFS
- Interfaces Details
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- UL 60950, FCC, RoHS, WEEE, REACH, IP66
- Power Requirements
- DC 12 V / PoE - 1 A
- Power Device
- 5 Watt
- Software Included
- TRENDnetVIEW Pro
- Limited warranty - 3 years
- -25 °C
- 60 °C
- Relative Humidity (operating)
- 0 - 90% (non-condensing)
