TRENDnet Outdoor 3MP Full HD PoE Dome Day/Night Network Camera
Quicklinx: 9F67WS00 Mfr#: TV-IP311PI
The Outdoor 3MP Full HD PoE Day/Night Network Camera, model TV-IP311PI, provides powerful 3 megapixel night vision in complete darkness for up to 25 meters (82 ft.). This ultra-compact vandal resistant fixed dome camera is outdoor ready with an IP66 weather rated housing. It comes with a free Apple® and Android™ mobile app and Complimentary pro-grade software to manage up to 32 TRENDnet cameras.
Hardware
PoE - Save installation costs with Power over Ethernet (PoE)
Power Port
Optional power port for non-PoE installation
Outdoor Ready
Outdoor IP66 weather rated
Vandal Resistant
Impact protection rated: IEC60068-275Eh, 50J; EN50102, exceeding IK10
Performance
3 Megapixel
Record 2048 x 1538 pixel video at 15 fps in H.264 compression
Night Vision
Night vision up to 25 meters (82 ft.) in complete darkness
Smart IR
Dynamic IR adjustment optimizes night visibility
Digital Zoom
Digitally zoom anywhere within the viewing field
IPv6
IPv6 support
Advanced Playback
Advanced in-camera archived video review functionality
D-WDR
Digital Wide Dynamic Range improves video quality in high contrast lighting environments
Storage
Samba video support with notification if storage drive is full
Free Apps
See live video on a mobile device with free Apple® and Android™ apps
Complimentary Software
TRENDnet TV IP311PI Outdoor 3 MP PoE Dome Day/Night Network Camera - network surveillance camera
Network surveillance camera - pan / tilt - outdoor - tamper-proof / weatherproof
11 cm x 11 cm x 8.2 cm
456 g
Wired
Camera
Colour - Day&Night
Max Resolution
2048 x 1536
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/3" - 3 MP
Minimum Illumination
0 lux - IR , 0.05 lux - colour
Focal Length
4 mm
Focus Adjustment
(min distance 20 cm)
Lens Iris
F/1.2
Panning Range (degree)
356
Tilting Range (degree)
15 to 90
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Backlight Compensation (BLC), digital noise reduction, date/time stamp, sharpness control, white balance, saturation control, brightness control, contrast control, e-mail alerts, image flip, image mirror, ONVIF support, manually schedule recording, Motion Detection Technology, built-in IR illuminator, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), hue control, ONVIF V2.2 (Profile S) support, reset button, Text Caption Overlay, snapshot function
3-year warranty
Environmental Parameters (operating)
-25 °C - 60 °C; 0 - 90% (non-condensing) relative humidity
Wired
11 cm
11 cm
8.2 cm
456 g
Camera
Colour - Day&Night - pan / tilt - outdoor - tamper-proof / weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Motion Detection
Video Capture
2048 x 1536 @ 15 fps , 1920 x 1080 @ 30 fps , 704 x 480 @ 30 fps
Still Image Capture Resolution
704 x 480, 2048 x 1536, 1920 x 1080
Image Sensor
3 MP CMOS 1/3"
Lens Construction
Focal Length
4 mm
Lens Iris
F/1.2
Min Focus Distance
20 cm
Horizontal Field of View (degree)
70
Vertical Field of View (degree)
52
Panning
Range (degree)
356
Tilting
Range (degree)
15 to 90
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, SSL, Samba, CIFS
Interfaces Details
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
UL 60950, FCC, RoHS, WEEE, REACH, IP66
Power Requirements
DC 12 V / PoE - 1 A
5 Watt
Software Included
TRENDnetVIEW Pro
Limited warranty - 3 years
-25 °C
60 °C
Relative Humidity (operating)
