TRENDnet Outdoor 2MP FHD Vari-Focal PoE Day/Night Dome Network Camera
Quicklinx: 9YMBWS00 Mfr#: TV-IP342PI
Hurry, only 3 left in stock!
£88.66 ex VAT
£106.39 inc VAT
The Outdoor 2MP Full HD PoE Day/Night Dome Network Camera, model TV-IP342PI, offers 15 m (50 feet) night vision, an IP66 weather rating, tamper detection, and 3x manual optical zoom for installation flexibility. Record full 1080p HD video (1920 x 1080) at 30 fps in a space saving H.264 compression format.
  • Vari-focal
    Manual optical zoom by a factor of 3 (and manually re-focus) to a final fixed position for installation flexibility position for installation flexibility.
  • Night vision
    Night vision up to 15 meters (50 ft.).
  • PoE
    Save installation costs with Power over Ethernet (PoE).
  • IP66 rating
    Outdoor IP66 weather rated housing.
  • Fixed pan tilt
    Pan and tilt the camera to its final fixed position.
  • BNC port
    BNC analog video out port to connect directly to a television for installation flexibility.
  • Resolution
    Record 2 Megapixel Full 1080p HD, 1920 x 1080 at 30 fps, in the space saving H.264 compression format.
  • Samba support
    Record video to a defined network storage device.
  • Tamper detection
    Receive tamper detection video clips via email, ftp, or save to network storage device or Micro-SD card.
  • D-WDR
    Improved image quality in high contrast light environments with Digital Wide Dynamic Range technology.
  • Motion detection
    Create up to 3 motion detection windows with separate sensitivity settings and event triggers.
TRENDnet TV IP342PI - network surveillance camera
Network surveillance camera - fixed dome - outdoor
Audio
Yes: two-way audio capability
Wired
Camera
Colour - Day&Night
Optical Zoom
3 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.7"
Focal Length Control
Vari-focal
Focal Length
3 mm - 9 mm
Lens Iris
F/1.8
Panning Range (degree)
330
Tilting Range (degree)
60
microSD card slot, ONVIF V2.2 (Profile S) support
3-year warranty
Environmental Parameters (operating)
-20 °C - 50 °C
Audio Support
Wired
Camera
Colour - Day&Night - fixed dome - outdoor
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Video Capture
1920 x 1080 @ 30 fps
Still Image Capture Resolution
1920 x 1080
Image Sensor
CMOS 1/2.7"
Lens Construction
Vari-focal
Optical Zoom
3 x
Focal Length
3 mm - 9 mm
Lens Iris
F/1.8
Panning
Range (degree)
330
Titling
Range (degree)
60
Network Protocols
IPv4, IPv6
1 x network , 1 x audio - input , 1 x audio - output
Mounting kit
IP66
6.7 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
-20 °C
50 °C
Brand: TRENDnet
Price Range Ex VAT: 50 - 100
