The megapixel HD wireless day/night PTZ network camera, model TV-IP662WI, provides day and night monitoring over a large area. Pan and tilt the camera from a mobile device, record video to a Micro SD card, and have the camera email motion detection video clips. A wall/ceiling mounting kit is included and the camera's off white housing blends into most environments.
- TRENDnet TV IP662WI Megapixel HD Wireless Day/Night PTZ Network Camera - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor
- Audio
- Yes: two-way audio capability, built-in microphone
- 10 cm x 11.3 cm x 12.8 cm
- 326 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/4" - 1 MP
- Minimum Illumination
- 1 lux - colour , 0 lux - IR
- Focal Length Control
- Motorized zoom
- Focal Length
- 4.6 mm
- Focus Adjustment
- (min distance 20 cm)
- Lens Iris
- F/2.0
- Panning Range (degree)
- 330
- Tilting Range (degree)
- 115
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external - 1.8 m
- Voltage
- DC 12 V
- White balance, saturation control, contrast control, e-mail alerts, image flip, image mirror, auto patrol, Motion Detection Technology, microSD card slot, Sound Detection Sensor, hue control, ONVIF V2.2 (Profile S) support, reset button
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 0 - 90% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 10 cm
- 11.3 cm
- 12.8 cm
- 326 g
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor
- Digital Video Format
- MPEG-4, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Digital Zoom
- 4
- Exposure Range
- 1/3.75 sec - 1/15 sec
- Video Capture
- 1280 x 720 @ 30 fps , 640 x 480 @ 30 fps
- Still Image Capture Resolution
- 1280 x 720, 640 x 480
Image Sensor
- 1 MP CMOS 1/4"
Lens Construction
- Motorized zoom
- Focal Length
- 4.6 mm
- Lens Iris
- F/2.0
- Min Focus Distance
- 20 cm
- Horizontal Field of View (degree)
- 49
- Vertical Field of View (degree)
- 31
Panning
- Range (degree)
- 330
Tilting
- Range (degree)
- 115
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, Bonjour, RTCP, PPPoE, Samba, 3GPP/ISMA, CIFS
- Ports
- LAN - RJ-45 , Audio line out - 3.5 mm jack
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - output - mini-phone 3.5 mm
- Supported Memory Cards
- microSD Card
- Included Accessories
- Mounting bracket
- Cables Included
- 1 x network cable - external - 1.8 m
- Power Requirements
- DC 12 V - 1 A
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 10.5 Watt
- Software Included
- Drivers & Utilities, TRENDnetVIEW Pro
- OS Required
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90% (non-condensing)
