The LMR200 Reverse SMA to N-Type Cable extends your wireless Antenna up to 2 meters to provide optimal placement for your antenna outdoors. Connect business networks from building to building wirelessly or provide wireless Internet access for hot spot applications! This cable makes wireless communication possible by providing low loss communication between your access point and antenna.
- TRENDnet TEW-L202 - antenna cable - TAA Compliant - 2 m
- Antenna cable
- Length
- 2 m
- Connector
- SMA - female
- Connector (Second End)
- N-Series connector - male
- TAA Compliant
- Network Cable Type
- Antenna cable
- Jacket Material
- Polyethylene
- Impedance
- 50 Ohm
- Length
- 2 m
- Connector
- SMA - female
- TAA Compliant
- -40 °C
- 85 °C
