TRENDnet Gigabit Power over Ethernet (PoE) Injector
Quicklinx: 9YMYWS00 Mfr#: TPE-113GI
£20.34 ex VAT
£24.40 inc VAT
The Gigabit Power over Ethernet injector, model TPE-113GI, combines electrical power with a gigabit network connection to produce a Gigabit Power over Ethernet (PoE) signal. Connect this device to a non-PoE switch and then run an Ethernet cable for up to 100 meters to network PoE devices.
No need to buy a PoE switch - use an existing open port from a non-PoE switch to save installation and equipment costs when installing TRENDnet PoE access points and IP cameras in remote locations. This compact device safeguards valuable network equipment with short circuit protection. Quickly create an integrated PoE and non-PoE network at gigabit speeds.
TRENDnet TPE-113GI - PoE injector - 15.4 Watt
PoE injector - external
45 g
Input Voltage
AC 100-240 V
Power Capacity
15.4 Watt
Input Connectors
1 x power
Output connectors
1 x RJ-45
Power adapter
7 cm x 4.5 cm x 2.5 cm
3-year warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
1 x power
15.4 Watt
1 x RJ-45
Power Capacity
15.4 Watt
1 x Gigabit LAN - RJ-45
Power adapter
Wall mountable, short-circuit protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, Plug and Play, FCC
Limited warranty - 3 years
50 °C
0 - 90% (non-condensing)
7 cm
4.5 cm
2.5 cm
45 g
