TRENDnet's model TPE-E110 extends and amplifies a Gigabit PoE or PoE+ network connection to a remote location. It auto-detects a PoE or PoE+ signal and extends it an additional meters from the PoE device. A rugged metal enclosure and no need for an external power adapter facilitate remote installations.
- TRENDnet TPE-E110 - repeater - 10Mb LAN, 100Mb LAN, 1GbE
- Repeater - RJ-45 / RJ-45
- Form Factor
- External
- Cabling Type
- 10Base-T, 100Base-TX, 1000Base-T
- Data Transfer Rate
- 2 Gbps
- Data Link Protocol
- Max Transfer Distance
- 100 m
- Power Over Ethernet (PoE)
- PoE+
- 12.5 cm x 7.5 cm x 3.3 cm
- 306 g
- 3-year warranty
- Repeater
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 2 Gbps
- MAC Address Table Size
- 2K entries
- 100 m
- Status Indicators
- Power
- IGMP snooping, half duplex mode, full duplex mode, wall mountable, cascadable, rugged, 96KB packet buffer, metal housing
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ input) - RJ-45 female , 1 x Ethernet 10Base-T/100Base-TX/1000Base-T (PoE+ output) - RJ-45 female
- FCC
- PoE+
- 2 Watt
- 12.5 cm
- 7.5 cm
- 3.3 cm
- 306 g
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 90% (non-condensing)
