Designed to handle multiple HD streams in a busy connected home, TRENDnet's AC750 Dual Band Wireless Router, model TEW-810DR, creates two concurrent wireless networks--a high speed 433 Mbps Wireless AC network and a 300 Mbps Wireless N network to connect common wireless devices.
Ease of Use, Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Security
Encrypted Wireless
For your security the router arrives pre-encrypted with its own unique password
Guest Network
Create secure isolated guest networks for internet access only
Parental Controls
Control access to specific websites or types of content
Performance
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Simultaneous Dual Band
High speed 433 Mbps Wireless AC band + 300 Mbps Wireless N
Ethernet Ports
Ethernet ports maintain high performance network connections
Backward Compatible
Compatible with Wireless N and older Wireless G devices
Energy Savings
Embedded GREENnet technology reduces power consumption by up to 50%
IPv6
IPv6 network support
*Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions
Easy setup
Get up and running in minutes with the intuitive guided setup. -
One touch connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button. -
Encrypted wireless
For your security the router arrives pre-encrypted with its own unique password. -
Guest network
Create secure isolated guest networks for internet access only. -
Parental controls
Control access to specific websites or types of content. -
Next generation wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home. -
Simultaneous dual band
High speed 433 Mbps wireless AC band + 300 Mbps wireless N. -
Ethernet ports
Ethernet ports maintain high performance network connections. -
Energy savings
Embedded GREENnet technology reduces power consumption by up to 50%.
- TRENDnet TEW-810DR - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 733 Mbps
- DDNS
- NAT support, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, GREENnet technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), bandwidth control
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- Power
- AC 120/230 V (50 - 60 Hz)
- 15.1 cm x 11.3 cm x 6 cm
- 187 g
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 733 Mbps
- DDNS
- Encryption Algorithm
- WPA2
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0), FCC
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
- Power Device
- External power adapter
- Voltage Required
- 8 Watt
- Cables Included
- 1 x network cable - 1.5 m
- 15.1 cm
- 11.3 cm
- 6 cm
- 187 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
