TRENDnet AC750 Dual Band Wireless Router
Quicklinx: 962GWS00 Mfr#: TEW-810DR
  • IEEE 802.11n
Designed to handle multiple HD streams in a busy connected home, TRENDnet's AC750 Dual Band Wireless Router, model TEW-810DR, creates two concurrent wireless networks--a high speed 433 Mbps Wireless AC network and a 300 Mbps Wireless N network to connect common wireless devices.
Ease of Use, Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Security
Encrypted Wireless
For your security the router arrives pre-encrypted with its own unique password
Guest Network
Create secure isolated guest networks for internet access only
Parental Controls
Control access to specific websites or types of content
Performance
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Simultaneous Dual Band
High speed 433 Mbps Wireless AC band + 300 Mbps Wireless N
Ethernet Ports
Ethernet ports maintain high performance network connections
Backward Compatible
Compatible with Wireless N and older Wireless G devices
Energy Savings
Embedded GREENnet technology reduces power consumption by up to 50%
IPv6
IPv6 network support
*Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions
  • Easy setup
    Get up and running in minutes with the intuitive guided setup.
  • One touch connection
    Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button.
  • Encrypted wireless
    For your security the router arrives pre-encrypted with its own unique password.
  • Guest network
    Create secure isolated guest networks for internet access only.
  • Parental controls
    Control access to specific websites or types of content.
  • Next generation wireless AC
    802.11ac provides uninterrupted HD video streaming in a busy connected home.
  • Simultaneous dual band
    High speed 433 Mbps wireless AC band + 300 Mbps wireless N.
  • Ethernet ports
    Ethernet ports maintain high performance network connections.
  • Energy savings
    Embedded GREENnet technology reduces power consumption by up to 50%.
TRENDnet TEW-810DR - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
733 Mbps
Network / Transport Protocol
DDNS
NAT support, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, GREENnet technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), bandwidth control
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
AC 120/230 V (50 - 60 Hz)
15.1 cm x 11.3 cm x 6 cm
187 g
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
733 Mbps
DDNS
Encryption Algorithm
WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0), FCC
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
External power adapter
8 Watt
1 x network cable - 1.5 m
15.1 cm
11.3 cm
6 cm
187 g
Limited warranty - 3 years
0 - 95% (non-condensing)
