TRENDnet's AC1750 Dual Band Wireless Router, model TEW-823DRU, is an extreme performance wireless router. It creates two concurrent wireless networks --a 1300 Mbps Wireless AC network and a 450 Mbps Wireless N network to connect common wireless devices. Use the USB port and Gigabit Ethernet ports to further expand your network.
Easy Setup
Get up and running in minutes with the intuitive guided setup
One Touch Connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
USB Share Port
Plug in a flash or storage drive into the USB port
Encrypted Wireless
For your convenience the router arrives pre-encrypted with its own unique password
Guest Network
Create an isolated network for guest internet access only
Parental Controls
Control access to specific websites or types of content
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home
Simultaneous Dual Band
High speed 1300 Mbps Wireless AC band + 450 Mbps Wireless N
Gigabit Ports
Gigabit ports extend high performance wired connections
Wireless Coverage
Whole home wireless coverage for average size homes
Backward Compatible
Compatible with legacy wireless devices
Targeted Beamforming
Increased real-time performance by directing stronger wireless signals to your specific location
Energy Savings
Embedded GREENnet technology reduces power consumption by up to 50%
- TRENDnet TEW-823DRU - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1300 Mbps
- PPTP, L2TP, IPSec, DHCP, CSMA/CA, DDNS, DHCPv6
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- VoIP Protocols
- H.323, SIP
- Firewall protection, NAT support, Stateful Packet Inspection (SPI), ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, GREENnet technology, firmware upgradable, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), Samba support, FTP server, reset button, pre-encrypted
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft 2.0)
- Power
- AC 120/230 V (50/60 Hz)
- 7.2 cm x 15.1 cm x 19.1 cm
- 408 g
- 3 years warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1300 Mbps
- Selectable Channels Qty
- 13
- Routing Protocol
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac (draft 2.0), FCC
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
IP Telephony
- VoIP Protocols
- H.323, SIP
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 6
- Power Device
- External power adapter
- Voltage Required
- 18 Watt
- Cables Included
- 1 x network cable - 1.5 m
- Software Included
- Drivers & Utilities
- 7.2 cm
- 15.1 cm
- 19.1 cm
- 408 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
