TRENDnet 8-port Gigabit GREENnet Switch
Quicklinx: 9YKNWS00 Mfr#: TEG-S81g
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 in stock
£20.36 ex VAT
£24.43 inc VAT
The compact 8-Port Gigabit GREENnet Switch provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70%. GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings.
Boost your office efficiency and eliminate network congestion with Gigabit speeds. Plug and Play this sturdy metal switch for reliable high speed network connectivity.
TRENDnet TEG S81g 8-Port Gigabit GREENnet Switch - switch - 8 ports
Switch - 8 ports
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Forwarding performance: 16 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, MAC address filtering, half duplex mode, full duplex mode, Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
17.1 cm x 10 cm x 3.1 cm
190 g
3-year warranty
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45
External power adapter
3.5 Watt
FCC, RoHS, WEEE
17.1 cm
10 cm
3.1 cm
190 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Ports: 8
Managed: No
POE: No
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
