Product
TRENDnet 5-port Hardened Industrial Gigabit PoE+ DIN-Rail Switch
Quicklinx: CNQXWS00 Mfr#: TI-PG541
Type: Gigabit Ethernet
Ports: 5
POE: PoE+
Hurry, only 2 left in stock!
£156.90 ex VAT
£188.28 inc VAT
TRENDnet's TI-PG541 is a reliable IP30 unmanaged PoE+ DIN-rail switch with hardened components rated for extreme industrial environments. It offers four Gigabit PoE+ ports, one Gigabit port, one SFP slot, and a full PoE power budget of 120 watts. Dual redundant power inputs with overload current protection support zero downtime requirements. An alarm output can be triggered by a primary and/or redundant power failure.
  • Full PoE+ power budget
    Supplies up to 30 watts of PoE/PoE+ power per port with a 120 watt PoE power budget.
  • Integrated DIN-rail mount
    IP30 rated metal enclosure with integrated DIN-rail mounting hardware.
  • Redundant power
    Dual redundant power inputs with overload current protection.
  • Alarm output
    Alarm output is triggered by power failure of primary and/or redundant power.
  • Jumbo frame
    Sends larger packets, or jumbo frames, for increased performance.
  • Extreme temperatures
    Hardened switch is rated for an operating temperature range of -40 to 70 °C (-40 to 158 °F).
  • Electro magnetic compliance
    Complies with IEC61000-6-2 EMC generic standard immunity for industrial environments.
  • LED indicators
    LED indicators convey power, redundant power, alarm, SFP, and network port status.
  • Grounding point
    Grounding point protects equipment from external electrical surges.
TRENDnet TI-PG541 - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 1 x 10/100/1000 + 1 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Switching capacity: 12 Gbps , Forwarding performance: 8.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Auto-negotiation, store and forward, half duplex mode, full duplex mode, surge protection, 512KB packet buffer, built-in DIP switch, 8KV ESD Protector, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
Power Redundancy
Optional
3 cm x 10 cm x 13.5 cm
500 g
3 years warranty
Switch - 5 ports
Enclosure Type
DIN rail mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
8K entries
Jumbo Frame Support
10KB
4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 , 1 x SFP
External power adapter
Installed Qty
0
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
160 Watt
130 Watt
FCC, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, IP30, IEC 61000-6-2:2005
3 cm
10 cm
13.5 cm
500 g
Limited warranty - 3 years
-20 °C
60 °C
0 - 95% (non-condensing)
Ports: 5
POE: PoE+
Brand: TRENDnet
Price Range Ex VAT: 150 - 300
