TRENDnet 24-port Gigabit GREENnet Rack Mount Switch
Quicklinx: 9YKVWS00 Mfr#: TEG-S24g
The 24-port Gigabit GREENnet Switch TEG-S24g provides high bandwidth performance, ease of use and reliability, all while reducing power consumption by up to 70%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office network efficiency and eliminate network congestion with Gigabit speeds and a total switching capacity of 48 Gbps with full-duplex mode. A built in universal power supply reduces cable clutter and diagnostic LEDs help with network troubleshooting. Plug and Play this sturdy metal switch for reliable high-speed network connectivity.
TRENDnet TEG S24G - switch - 24 ports - rack-mountable
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, packet filtering, store and forward, half duplex mode, full duplex mode, GREENnet technology, Jumbo Frames support, port forwarding
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
28 cm x 18 cm x 4.4 cm
1.7 kg
3-year warranty
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Port transmission speed, power, link/activity
24 x 1000Base-T RJ-45
Internal power supply
13 Watt
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
28 cm
18 cm
4.4 cm
1.7 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
