TRENDnet 18-Port Gigabit High Power PoE+ Switch
Quicklinx: FQ92WS00 Mfr#: TPE-TG182F
£289.26 ex VAT
£347.11 inc VAT
TRENDnet's 18-port Gigabit High Power PoE+ switch, model TPE-TG182F, reduces equipment and installation costs by delivering data and power over existing Ethernet cables. This rack-mountable, high-power PoE switch provides 16 gigabit PoE+ ports with a total PoE power budget of 440W. It also features two additional shared RJ-45 or SFP gigabit ports. The TPE-TG182F high-power PoE switch supplies up to 30W of power per port for devices such as high-power wireless access points, PTZ (Pan/Tilt/Zoom) IP cameras, and VoIP phone systems.
TRENDnet TPE TG182F - switch - 18 ports - rack-mountable
Switch - 18 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+) + 2 x combo Gigabit Ethernet/Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
440 W
Performance
Switching capacity: 36 Gbps , Forwarding performance (64-byte packet size): 26.78 Mpps , Buffer memory: 512 KB
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Half duplex mode, full duplex mode, metal housing
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
44 cm x 19.6 cm x 4.4 cm
3.05 kg
Switch - 18 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
440 W
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Status
16 x 1000Base-T RJ-45 PoE+
Internal power supply
Rack Mounting Kit
Included
FCC, ETL, CE/EMC
44 cm
19.6 cm
4.4 cm
3.05 kg
Limited warranty - lifetime , Limited warranty - power supply and fans - 1 year
90% (non-condensing)
Brand: TRENDnet
