Your basket is empty
TRENDnet 16-port 10/100Mbps PoE+ Switch
Quicklinx: 9YNBWS00 Mfr#: TPE-T160H
The 16-port 10/100 Mbps PoE+ switch, model TPE-T160H, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as access points and IP cameras. It supplies up to 30 Watts of power per port with a 250 Watt power budget.
TRENDnet TPE T160H - switch - 16 ports - rack-mountable
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
250 W
Performance
Switching capacity: 3.2 Gbps , Forwarding performance (64-byte packet size): 2.38 Mpps
MAC Address Table Size
4K entries
Half duplex mode, full duplex mode, GREENnet technology, 1.25MB packet buffer
IEEE 802.3u, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
44 cm x 22 cm x 4.4 cm
3 kg
3 years warranty
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100 (PoE+)
PoE+
PoE Budget
250 W
Performance
4K entries
16 x 100Base-TX RJ-45 PoE+ - 30 W
Internal power supply
260 Watt
Rack Mounting Kit
Included
FCC
44 cm
22 cm
4.4 cm
3 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
