The 16-Port 10/100Mbps GREENnet switch provides improved bandwidth, ease of use, and reliability, all while reducing power consumption by up to 40%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office efficiency and reduce network congestion with a total switching capacity of 3.2Gbps with full-duplex mode. Plug and play this sturdy metal rackmount switch for reliable high-speed network connectivity.
- TRENDnet TE100 S16g - switch - 16 ports
- Switch - 16 ports
- Enclosure Type
- 1U
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- MAC Address Table Size
- 8K entries
- Flow control, uplink, auto-sensing per device, MDI/MDI-X switch, half duplex mode, full duplex mode, GREENnet technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 14 cm x 4.4 cm
- 1.7 kg
- 5-year warranty
- Switch - 16 ports
- Enclosure Type
- Desktop 1U
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- 8K entries
- Built-in Devices
- Led panel
- Status Indicators
- Collision status, port duplex mode, power, link/activity
- 16 x 100Base-TX RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 6 Watt
- Rack Mounting Kit
- Included
- Plug and Play, FCC, RoHS
- 44 cm
- 14 cm
- 4.4 cm
- 1.7 kg
- Limited warranty - 5 years
- 0 °C
- 50 °C
- 10 - 90%
