TRENDnet 16-Port 10/100Mbps GREENnet Switch
Quicklinx: B4G1WS00 Mfr#: TE100-S16g
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£38.28 ex VAT
£45.93 inc VAT
The 16-Port 10/100Mbps GREENnet switch provides improved bandwidth, ease of use, and reliability, all while reducing power consumption by up to 40%.
GREENnet technology automatically adjusts power voltage as needed, resulting in substantial energy savings. Embedded GREENnet technology works right out of the box with no management requirement.
Boost office efficiency and reduce network congestion with a total switching capacity of 3.2Gbps with full-duplex mode. Plug and play this sturdy metal rackmount switch for reliable high-speed network connectivity.
TRENDnet TE100 S16g - switch - 16 ports
Switch - 16 ports
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
16 x 10/100
MAC Address Table Size
8K entries
Flow control, uplink, auto-sensing per device, MDI/MDI-X switch, half duplex mode, full duplex mode, GREENnet technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
44 cm x 14 cm x 4.4 cm
1.7 kg
5-year warranty
Switch - 16 ports
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
16 x 10/100
8K entries
Built-in Devices
Led panel
Status Indicators
Collision status, port duplex mode, power, link/activity
16 x 100Base-TX RJ-45
Internal power supply
6 Watt
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
44 cm
14 cm
4.4 cm
1.7 kg
Limited warranty - 5 years
50 °C
10 - 90%
Type: Fast Ethernet
Ports: 16
Managed: No
POE: No
Brand: TRENDnet
