TRENDnet 16-Channel HD NVR
Quicklinx: CK2DWS00 Mfr#: TV-NVR2216
TRENDnet’s standalone 16-Channel HD NVR, model TV-NVR2216, offers a comprehensive rack mountable video display, storage, and management solution. The NVR networks up to sixteen cameras and auto-recognizes TRENDnet models. Install up to 12 TB of storage (hard drives not included) to record continuous or event-based video from sixteen HD cameras. The TV-NVR2216 features advanced video playback with free iOS and Android apps.
  • Standalone 1080p HD NVR
    This 1080p HD NVR supports up to a 12 TB hard drive and networks up to eight network cameras-hard drive, cameras, and display sold separately.
  • Easy installation
    The NVR auto-recognizes TRENDnet cameras - simply connect compatible TRENDnet cameras and start recording surveillance video.
  • Intuitive interface
    Users will find the management interface intuitive and easy to use - quickly navigate live view preferences, recording schedules, and advanced playback options.
TRENDnet TV-NVR2216 - standalone NVR - 16 channels
NVR - 16 channels - networked - rack-mountable
IP Cameras Supported
16
Frame Rate
30 fps (record) / 60 fps (playback)
Compression Format
H.264
Image Resolution
1600x1200, 1280x720, 1920x1080, 1024x768, 1280x1024
Hard Drive(s) Supported
Quantity: 2 - total capacity: 12 TB
Voltage
120 / 230 V
44.5 cm x 29 cm x 4.5 cm
1 kg
2 years
NVR - rack-mountable
Video Channels
16
16
Image Resolution
Compression Format
H.264
Package Content
Remote control, external power adapter, software, cables, mouse, rack mount bracket
Network cable - 1.8 m - 1 pcs. , HDMI cable - 1.8 m - 1 pcs.
UL, FCC
Warranty
2 years
Security DVR
Frame Rate (Playback)
60 fps
Frame Rate (Record)
30 fps
Display Modes
9 split screens, 4 split screens, 1+7 split screens, 1+5 split screens
Record Events
Motion detection, scheduled, continuous, tamper detection, video loss
Networked
Brightness adjustment, contrast adjustment
Hard Drive
Quantity Supported
2
Serial ATA
Removable
Supported Max Total Capacity
12 TB
Video Server
ONVIF compliant
DDNS Support
Web Server
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, UPnP, TLS, IPv4, IPv6, RTCP, SSL, PSIA, SNMP 2
Firmware upgradable, on/off switches, Auto Scan Mode, Pan, Tilt, Zoom (PTZ) control signals transmission
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 1
Audio Output Ports
RCA x 1
Network Port
10/100/1000Base-T
Other Ports
USB 2.0, USB 3.0 x 1
Voltage
120 / 230 V
Frequency
50/60 Hz
Power Consumption
10 Watt
44.5 cm
29 cm
4.5 cm
1 kg
-10 °C
55 °C
0 - 90% (non-condensing)
