TRENDnet’s standalone 16-Channel HD NVR, model TV-NVR2216, offers a comprehensive rack mountable video display, storage, and management solution. The NVR networks up to sixteen cameras and auto-recognizes TRENDnet models. Install up to 12 TB of storage (hard drives not included) to record continuous or event-based video from sixteen HD cameras. The TV-NVR2216 features advanced video playback with free iOS and Android apps.
Standalone 1080p HD NVR
This 1080p HD NVR supports up to a 12 TB hard drive and networks up to eight network cameras-hard drive, cameras, and display sold separately. -
Easy installation
The NVR auto-recognizes TRENDnet cameras - simply connect compatible TRENDnet cameras and start recording surveillance video. -
Intuitive interface
Users will find the management interface intuitive and easy to use - quickly navigate live view preferences, recording schedules, and advanced playback options.
- TRENDnet TV-NVR2216 - standalone NVR - 16 channels
- NVR - 16 channels - networked - rack-mountable
- IP Cameras Supported
- 16
- Frame Rate
- 30 fps (record) / 60 fps (playback)
- Compression Format
- H.264
- Image Resolution
- 1600x1200, 1280x720, 1920x1080, 1024x768, 1280x1024
- Hard Drive(s) Supported
- Quantity: 2 - total capacity: 12 TB
- Voltage
- 120 / 230 V
- 44.5 cm x 29 cm x 4.5 cm
- 1 kg
- 2 years
- NVR - rack-mountable
- Video Channels
- 16
- 16
- Image Resolution
- H.264
- Package Content
- Remote control, external power adapter, software, cables, mouse, rack mount bracket
- Cables Included
- Network cable - 1.8 m - 1 pcs. , HDMI cable - 1.8 m - 1 pcs.
- UL, FCC
- Warranty
- 2 years
Security DVR
- Frame Rate (Playback)
- 60 fps
- Frame Rate (Record)
- 30 fps
- Display Modes
- 9 split screens, 4 split screens, 1+7 split screens, 1+5 split screens
- Record Events
- Motion detection, scheduled, continuous, tamper detection, video loss
- Networked
- Brightness adjustment, contrast adjustment
Hard Drive
- Quantity Supported
- 2
- Interface
- Serial ATA
- Removable
- Supported Max Total Capacity
- 12 TB
Video Server
- ONVIF compliant
- DDNS Support
- Web Server
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, UPnP, TLS, IPv4, IPv6, RTCP, SSL, PSIA, SNMP 2
- Firmware upgradable, on/off switches, Auto Scan Mode, Pan, Tilt, Zoom (PTZ) control signals transmission
- Video Output Ports
- HDMI x 1, VGA x 1
- Audio Input Ports
- RCA x 1
- Audio Output Ports
- RCA x 1
- Network Port
- 10/100/1000Base-T
- Other Ports
- USB 2.0, USB 3.0 x 1
- Voltage
- 120 / 230 V
- Frequency
- 50/60 Hz
- Power Consumption
- 10 Watt
- 44.5 cm
- 29 cm
- 4.5 cm
- 1 kg
- -10 °C
- 55 °C
- 0 - 90% (non-condensing)
