The 150 Mbps low profile Wireless N PCI adapter, model TEW-703PIL, connects a low profile desktop computer to a high speed wireless n network. This adapter installs quickly to a free PCI slot on a Window's based low profile desktop computer. An LED conveys wireless connection status. Advanced wireless encryption protects your valuable data. A detachable antenna gives users the ability to change the connected antenna. Stream media, download files, and play games on a desktop computer over a wireless connection.
- TRENDnet TEW-703PIL - network adapter - PCI
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI
- 12 cm x 4.4 cm
- 55 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- 3-year warranty
- Network adapter
- Form Factor
- PCI
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 150 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
- Frequency Band
- 2.4 GHz
- Selectable Channels Qty
- 13
- Status Indicators
- Link/activity
- Ad-Hoc Mode, RADIUS support
Aerial
- Antenna
- External detachable
- Gain Level
- 2 dBi
- 1 x aerial - R-SMA
- Compatible Slots
- 1 x PCI
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- ETSI, FCC
- Software Included
- Drivers & Utilities
- OS Required
- 12 cm
- 4.4 cm
- 55 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
