TRENDnet's TFC-110 series Fiber Media Converter transforms 10/100BaseTX UTP/STP media to 100BaseFX media and vice versa. The 10/100BaseTX port auto-senses 10 or 100Mbps connection speed, auto-negotiates half-/full-duplex mode, and auto-selects MDI-X / MDI-II media type. The fiber connection can be multi-mode SC, MT-RJ, or single-mode SC Connector and it has a slide-switch for selecting half- or full-duplex mode. This converter will give your Switch/Hub the ability to interface with fiber connection over a distance up to 75 km. With the optional 16-slot EIA-19" rack-mount chassis, the TFC series converters are the perfect solutions for various fiber media conversions for your network.
- TRENDnet TFC-110 MSC - fibre media converter - 10Mb LAN, 100Mb LAN - TAA Compliant
- Fibre media converter - SC multi-mode / RJ-45
- Form Factor
- External
- Cabling Type
- 10Base-T, 100Base-FX, 100Base-TX
- Data Transfer Rate
- 100 Mbps
- Data Link Protocol
- Max Transfer Distance
- 2 km
- 12 cm x 8.8 cm x 2.5 cm
- 0.4 kg
- TAA Compliant
- Limited lifetime warranty
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 100 Mbps
- 2 km
- Status Indicators
- Port transmission speed, port duplex mode, power, link/activity
- Full duplex capability, auto-sensing per device, MDI/MDI-X switch, auto-negotiation
- IEEE 802.3, IEEE 802.3u
- 1 x Ethernet 100Base-FX - SC multi-mode female x 2 , 1 x Ethernet 10Base-T/100Base-TX - RJ-45 female
- Rack Mounting Kit
- Optional
- VCCI
- TAA Compliant
- Power Device
- External power adapter
- Power Provided
- 7.2 Watt
- 12 cm
- 8.8 cm
- 2.5 cm
- 0.4 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 90%
