Transcend Suction Mount for DrivePro 200 Car Video Recorder
Quicklinx: 9Z5ZWS00 Mfr#: TS-DPM1
Suction mount TS-DPM1 is compatible with Transcend DrivePro 200 Car Video Recorders. Easy to install, locking T tip (easy to adjust desired angle) and 360 degree swivel.
Product Features
  • Locking T tip, easy to adjust desired angle
  • Suction pad
  • 360 degree swivel
  • Easy to install
  • Suitable for Transcend Car Video Recorder Series
  • Sturdy support system
    The Transcend TS-DPM1 features a robust support system that firmly holds dashboard cameras in place, ensuring uninterrupted recording while driving.
  • Simple installation
    With its suction mount design, this tripod allows for a straightforward setup on the windshield, making it user-friendly.
Transcend TS-DPM1 support system - suction mount
Support system - suction mount
Placing / Mounting
Wind shield
DrivePro 200, 620
Support system
Tripod
Placing / Mounting
Wind shield
Supported Devices
Dashboard camera
Support Type
Suction mount
Transcend DrivePro 200, 620
