One plus one is greater than two. Transcend's StoreJet 25M3 portable hard drive combines the advantages of Transcend's shockproof StoreJet M series and the next-generation SuperSpeed transfer rates of USB 3.0, allowing users to enjoy ultra-fast file transfers and the high level of anti-shock protection.
Besides its outstanding combination of super fast transfer speeds and extra-rugged anti-shock design, the StoreJet 25M3 is equipped with an extremely convenient one touch auto-backup button. Now you can instantly backup, synchronize and copy large files without having to waste precious time waiting for the transfer to complete.
- Transcend StoreJet 25M3 - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- One-Click backup button
- Power Source
- USB bus
- 8.2 cm x 13 cm x 2 cm
- 216 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Internal Drive Interface
- Serial ATA
- Buffer Size
- 8 MB
- 8.2 cm
- 13 cm
- 2 cm
- 216 g
Performance
- Interface Transfer Rate
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Software Included
- StoreJet Software
- OS Required
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7, Linux Kernel 2.6.31 or later
- Cables Included
- 1 x USB 3.0 cable - external , 1 x USB power cable - external
- Plug and Play, BSMI, FCC
- Limited warranty - 3 years
- 5 °C
- 55 °C
