Your basket is empty
Transcend MTS600 256GB Solid State Drive - Internal - M.2 2260 - SATA 6Gb/s
Quicklinx: CCMQWS00 Mfr#: TS256GMTS600
Form Factor: M.2 2260
Capacity: 256GB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 3 left in stock!
£90.96 ex VAT
£109.15 inc VAT
Transcend's MTS600 M.2 SSD's next generation SATA III 6 Gb/s interface and ultra compact dimensions make it best suited to address the high performance needs and strict size limitations of small form factor devices. This means it is perfect for use in the modern Ultrabooks, thin and light notebooks, and tablets. With the SATA III 6 Gb/s specification, silicon motion controller, and exceptional transfer speeds of up to 560 MB/s read and 310 MB/s write, the M.2 SSD easily handles everyday computing tasks as well as demanding multimedia applications.
Transcend's SATA III 6 Gb/s MTS600 M.2 SSD supports Intel Smart Response Technology (ISRT), which allows you to configure your computer system with an SSD used as cache memory between the hard disk drive and system memory. This provides the advantage of having a hard disk drive for maximum storage capacity while delivering an SSD-like overall system performance experience.
ISRT works by monitoring which programs and files you access most frequently and stores them on the SSD. As a result, application launch speed and overall system responsiveness are significantly improved, while the large capacity of the hard drive is free to store all your other programs and files. In this configuration, only one drive letter is displayed; no additional drive letter is required for the SSD used as cache.
Transcend MTS600 - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
NAND Flash Memory Type
Multi-level cell (MLC)
M.2 2260
SATA 6Gb/s
Data Transfer Rate
600 MBps
Intel ISRTsupport
60 mm x 22 mm x 3.5 mm
7 g
3 years warranty
256 GB
M.2 2260
SATA 6Gb/s
Intel ISRTsupport
60 mm
22 mm
3.5 mm
7 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 310 MBps (write)
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2260
BSMI, FCC
Limited warranty - 3 years
70 °C
Transcend MTS600 256GB Solid State Drive - Internal - M.2 2260 - SATA 6Gb/s Bundle deal on Transcend MTS600 256GB Solid State Drive - Internal - M.2 2260 - SATA 6Gb/s
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £6.01 | in stock
£93.97
saving £3.01
Capacity: 256GB
Brand: Transcend
Price Range Ex VAT: 50 - 100
