Transcend DrivePro Body 10 Wearable Video Camera
Quicklinx: BW7SWS00 Mfr#: TS32GDPB10A
Day or night, indoors or outdoors, Transcend's DrivePro Body 10 is the best companion for police officers, security guards and other professionals. The camera's wide 160° viewing angle, ƒ/2.8 aperture lens and Full HD 1080P recordings ensure all the important details of actions are clearly recorded. The infrared LEDs will be automatically turned on in low light conditions, allowing recording and snapshots taking at night. The DrivePro Body 10 also features a built-in battery and excellent water and shock resistance, ideal for indoor and outdoor use.
  • Collect evidence day and night
    With a large ƒ/2.8 aperture, a wide 160° viewing angle and a high-quality camera lens, the DrivePro Body 10 can automatically adjust to different lighting conditions to capture all details of actions during either daytime or nighttime in clear and smooth 1080P (30 fps) recordings. In addition, as infrared LEDs turn on automatically on in low light, recording at night is now easier than ever before.
  • Firmly attached with 360° rotatable clip
    The DrivePro Body 10 features a 360° rotatable clip that allows you to attach it to clothing or straps, making it easier to record anytime, anywhere.
  • Built-in battery for frontline recording
    With a built-in 1530 mAh Li-Polymer battery, the DrivePro Body 10 can record long hours of footage on a full charge, mitigating the need for a power adapter for police officers on duty.
  • Handy snapshot button
    The handy snapshot feature allows you to take photos while recording video. During an incident, press the snapshot button to capture photographic evidence on the spot.
  • Optimum outdoor protection
    The rugged DrivePro Body 10 provides excellent protection for outdoor recording. The IPX4 water resistant feature offers protection against splashing water from any direction. The DrivePro Body 10 also offers excellent shock resistance, meeting U. S. military drop-test standards.
Transcend DrivePro Body 10 - camcorder - storage: flash card
Camcorder - 1080p
Media Type
Flash card
Memory Card Slot
microSD card
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens f/2.8
Focus Adjustment
Focus free
Supported Battery
Li-Polymer rechargeable battery - 1530 mAh (included)
USB 2.0
5.22 cm x 1.96 cm x 8.84 cm
108 g
Camcorder - 1080p
Camcorder Type
Wearable
Camcorder Media Type
Flash card
Frame Rate (Max Resolution)
30 fps
Digital Video Format
H.264, MOV
1920 x 1080
USB 2.0
Lens System
Focus Adjustment
Focus free
Max View Angle
160 degree(s)
Additional Features
Additional Features
Takes photos while film recording, built-in IR illuminator
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0
Swivel clip, micro-USB cable
Protection
Splashproof, shockproof
Battery Type
Lithium polymer - integrated
Details
Battery Life Details
Video recording - 3.5 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card
32 GB microSDHC
Memory Card Included
Video Capture
H.264 - 1920 x 1080 p - 30 fps
5.22 cm
1.96 cm
8.84 cm
108 g
-20 °C
65 °C
