For those who extremely care about the road and personal safety, the DrivePro 520 is an ideal dual lens car video recorder that provides its drivers and passengers with optimum protection. Featuring a 130° view angle, a large f/1.8 aperture and 6 glass lens, the front lens captures crystal-clear Full HD 1080P videos with every detail happening on the road. The 180° rotatable rear lens comes with the four infrared LEDs, allowing you to record sharp in-car videos at night or in low light conditions. Easy to install and operate, the DrivePro 520 even includes wireless connectivity to let you stream, download, and share videos whenever needed on your mobile devices.
Comprehensively record events with dual lens camera
To comprehensively protect the road and personal safety, the DrivePro 520 boasts a dual lens camera to record what happens on the road outside and inside your vehicle. With the innovative 6 glass lenses and a large f/1.8 aperture, the front lens can adjust to different lighting conditions to clearly capture events in resolution of Full HD 1080P during daytime and nighttime. The rear lens camera features the 180° rotatable design to ensure that all the important details of your trip and in-car situations can be recorded. -
Infrared LEDs make videos sharp at night
Featuring the four Infrared LEDs surrounded by the rear-lens camera, the DrivePro 520 provides ultra-clear in car recording for low light conditions and night vision. When low light conditions are detected, the Infrared LEDs will be automatically turned on to support rear image recording, offering you and passengers a high level in-car safety. -
An extremely durable microSDHC card for car video recorder use
Each 32GB microSDHC Class 10 UHS-I 600x memory card included in the DrivePro 520 is designed for car video recorder use. Built with top-tier MLC NAND flash chips, it provides the consistent long-life durability and endurance. -
Record every critical moment
In the event of a collision, the DrivePro 520's motion G-Sensor will detect the impact and instantly trigger emergency recording mode. Emergency recording mode protects the current recording, including the critical seconds before the accident, from being overwritten. In addition, If other situations occur outside, you can simply press the accessible emergency button to manually activate emergency recording, protecting you from a false or lawsuit. -
Instantly view and download videos on mobile devices
Supported by the free downloadable DrivePro520 App, the DrivePro 520 includes wireless connectivity to let you stream, download, and share videos on a iOS and Android smartphone and tablet - perfect for reporting incidents to insurance companies or the police. -
GPS receiver to log your driving records
DrivePro 520's built-in GPS receiver can log GPS coordinates, date and time into the recorded video footage. During an incident, the GPS coordinates can help you precisely locate where you are so as to contact the Emergency Road Service, the police or the insurance company. -
Convenient snapshot function
The convenient snapshot feature allows you to take photos while recording video. During an incident, you can also remove DrivePro 520 from the vehicle to capture collision damage on the spot.
- Transcend DrivePro 520 - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- microSD card
- Wireless Interface
- Wi-Fi
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens f/1.8
- Lens System (2nd)
- Wide-angle lens - f/2.8
- Focus Adjustment
- Focus free
- Display
- LCD display - 2.4"
- Real-Time Locations
- GPS / GLONASS
- Supported Battery
- Li-Polymer rechargeable battery - 430 mAh
- Interface
- USB 2.0
- 9.62 cm x 4.39 cm x 6.45 cm
- 108 g
- 2-year warranty
- Product Type
- Built-in Light
- IR illuminator
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Navigation
- GPS/GLONASS receiver
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- USB 2.0, IEEE 802.11b/g/n
- Connectivity Features
- Remote live view
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 130 degree(s)
Lens System (2nd)
- Focus Adjustment
- Focus free
Additional Features
- Additional Features
- Built-in speaker
Dashboard Camera Features
- GPS / GLONASS
- Two adjustable cameras
Display
- 2.4" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0
- Included Accessories
- Car power adapter, suction cup mount
- Battery Type
- Integrated
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card
- 32 GB microSDHC
- Memory Card Included
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps
- Limited warranty - 2 years
- 9.62 cm
- 4.39 cm
- 6.45 cm
- 108 g
