Transcend DrivePro 200 16Gb DashCam with Suction Mount
Quicklinx: BW7QWS00 Mfr#: TS16GDP200M
Day or night, the DrivePro Car Video Recorder is your dependable eyewitness on the road. Mounted on your windshield, the DrivePro automatically records every detail of your journey in high clarity as it happens. It even includes wireless smartphone connectivity to let you download and share videos whenever needed - perfect for reporting incidents to insurance companies or police.
  • Sharp video anytime
    Transcend's DrivePro 200 is aimed at helping you feel more confident and safer while driving. Mounted on your car's windshield, the DrivePro 200's camera combines an extra wide 160° viewing angle, resolution of 1920x1080p (30fps), and a row of 7 glass lenses to ensure your whole trip is recorded in high clarity as it happens. The large f/2.0 aperture means this lens will automatically adjust to light conditions to capture all details of an event, including license plates, in both day and night, while the built-in microphone can record sound if required.The evidence recorded by the DrivePro 200 can be used to protect and assist you in all manner of traffic incidents and fraudulent claims including: reporting incidents to the police, identifying the cause of an accident, and completing insurance claims. What's more, knowing that every action is recorded, it can be an excellent way for parents to encourage good driving behavior in young drivers.
  • Install and record
    Installing the DrivePro 200 is easy. Simply mount the DrivePro 200 in the middle of your car's windshield and connect the included car adapter from the DrivePro 200 to your car's lighter socket. Operating the DrivePro 200 is even easier. After starting your car's engine, the DrivePro 200 will automatically turn on and start recording video files. After the engine is switched off, the DrivePro 200 will automatically save the current recording and power off.
  • Wi-Fi and App QR codes
    Thanks to its built-in Wi-Fi and supported by the free downloadable DrivePro 200 App, for Apple iOS and Android devices, the DrivePro 200 can be operated by a passenger as the driver gets on with the task of driving. When connected to the DrivePro 200's dedicated wireless network, you can view live video footage during recording, playback and download videos, and easily adjust DrivePro 200 settings directly from your smartphone or tablet.
Transcend DrivePro 200 - dashboard camera
Dashboard camera - 1080p
Memory Card Slot
microSD card
Sensors
Gyro sensor
Wireless Interface
Wi-Fi
Sensor Resolution
3.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
F/2.0
Display
LCD display - 2.4"
Incident Detection
G-Sensor
Composite video/audio, USB 2.0
6.7 cm x 3.43 cm x 7.2 cm
84 g
Sensor Resolution
3.0 Megapixel
Sensor Qty
1 CMOS
Widescreen Video Capture
Optical Sensor Type
CMOS
Sensors
Gyro sensor
Digital Video Format
H.264, MOV
1920 x 1080
Composite video/audio, USB 2.0, IEEE 802.11b/g/n
Connectivity Features
Wireless Image Transfer, Live streaming
Lens System
F/2.0
Max View Angle
160 degree(s)
Lens Construction
7 elements
Additional Features
Additional Features
Built-in speaker
Dashboard Camera Features
Incident Detection
G-Sensor
Display
2.4" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video output
Car power adapter, composite video cable, suction cup mount
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card
16 GB microSDHC
Memory Card Included
Memory Card Max Supported Size
32 GB
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps
6.7 cm
3.43 cm
7.2 cm
84 g
-30 °C
65 °C
Min Storage Temperature
-30 °C
Max Storage Temperature
70 °C
