Your basket is empty
Transcend DrivePro, 2.4" LCD,with Adhesive Suction 16Gb
Quicklinx: C7R9WS00 Mfr#: TS16GDP100A
Type: Dashboard camera
Media Type: Flash card
Video Input: USB 2.0
£58.85 ex VAT
£70.62 inc VAT
Day or night, the DrivePro 100 car video recorder is your reliable eyewitness on the road. With a built-in battery, the recorder gives you extra seconds of recording in case of power failure, offering maximum assurance. The DrivePro 100's high-quality wide angle 6 glass lenses can capture snapshots and clear Full HD footage for display on a bright color LCD screen. Easy to operate, the DrivePro 100 also includes the Auto Power On/Off feature.
Transcend DrivePro 100 - dashboard camera
Dashboard camera - 1080p - widescreen
Memory Card Slot
microSD card
Sensors
Gyro sensor
Sensor Resolution
3.0 Megapixel
Lens System
Wide-angle lens - f/1.8
Display
LCD display - 2.4"
Incident Detection
G-Sensor
Supported Battery
1 x Li-Polymer rechargeable battery - 470 mAh (included)
USB 2.0
6.31 cm x 3.44 cm x 6.83 cm
72.6 g
2 years warranty
Sensor Resolution
3.0 Megapixel
Widescreen Video Capture
Optical Sensor Type
CMOS
Sensors
Gyro sensor
Digital Video Format
H.264, MOV
USB 2.0
Lens System
Max View Angle
130 degree(s)
Lens Construction
6 elements
Additional Features
Additional Features
Audio recording, built-in speaker, auto power save, takes photos while film recording
Dashboard Camera Features
Incident Detection
G-Sensor
Display
2.4" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0
Software
Software
Drivers & Utilities, Transcend DrivePro PC Tool
Car power adapter, adhesive mount
Details
Battery Life Details
Video recording - 0.5 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Included Memory Card
16 GB microSDHC
Memory Card Max Supported Size
32 GB
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps
6.31 cm
3.44 cm
6.83 cm
72.6 g
-20 °C
65 °C
Brand: Transcend
Price Range Ex VAT: 50 - 100
