Product
Brand
TP LINK WLAN-Antenna 2.4GHz 5dBi Indoor with Cable
Quicklinx: 898CWS00 Mfr#: TL-ANT2405C
The TL-ANT2405C is a 2.4GHz 5dBi indoor omni-directional antenna.
TP-Link TL-ANT2405C - antenna
Antenna
5 cm x 5 cm x 20.1 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Wall-mountable, indoor, desktop
Compatibility
802.11 b/g/n
Frequency Range
2.4 - 2.5 GHz
Gain
5 dBi
Directivity
Omni-directional
Plug and Play, FCC, RoHS
Antenna
5 cm
5 cm
20.1 cm
Cable Length
1 m
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g/n
Frequency Range
2.4 - 2.5 GHz
Gain
5 dBi
Directivity
Omni-directional
Voltage Standing Wave Ratio (VSWR)
1.92:1
Horizontal Beamwidth
360°
Vertical Beamwidth
15°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x SMA male
-10 °C
60 °C
10 - 90%
